Brief Description: Fit the battery mount to the fuselage
Fit the battery mount to the fuselage. Found that I d not like the way that I had planned to attach the mount to the lower longeron on both sides. I was going to mount an angle-angle combination under the longeron and bolt these angles to the longeron. What I found is that the angles that I was going to use were too far below the longeron once the mount was screwed to the baggage suuport ribs. Besides, I liked the idea of supporting the mount by having the angles rest on top of the longeron (vs under the longeron) before being bolted to the longeron. To make this change, I'll need to get some aluminum angle with wider sides that I will shape and fit to the longerons and the othe angle.
