Brief Description: Riveted the baggage door together
Riveted the baggage door together minus the inner skin. Had to use a shim attached to my bucking bar to maintain some angle relative to the rivet being riveted inside of the ribs. Without this shim, I had some poor shop heads. The heads varied in pitch and were often bent over or slurred to the side. I found it much easier to buck with the shim to help with positioning the bar relative to the rivet being driven.
Made and drilled the angles that secure the batteries to the mount.
