Brief Description: Connected F-846 pushrod to F-635 Elevator bellcran
Connected F-846 pushrod to F-635 Elevator bellcrank. Torqued nuts to 25 in. lbs. and applied torque seal. Did not torque the bellcrack nut at this time. I'll torque it at the time of the installation of the autopilot elevator servo.
Started fabricating an aft battery mount for the two Odessey batteries that I will be installing. I'll be mounting them upright, side by side. I decided to extend the mount to the side lower longerons and bolt them there for additional support. Any extra space will be used to mount battery contactors or other necessary parts of the electrical system. I'll drill lightening holes wherever possible.
