John (Jack) Clark's Web Site
RV-A8
Mounted the fuel pumps
Mounted the fuel pumps using AN3-5A bolts torqued to 25 in. lbs. A piece of rubber with adhesive on one side was placed between the pump bracket and the pump mount for additional vibration isolation.
View from right side
Top view - Front to the left
Rear view
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
