Brief Description: Riveted the rudder pedal angles to the floor
Riveted the rudder pedal angles to the fuselage forward floor. I had to use BSPQ5-4 pulled rivets because I had drilled all of the holes to 5/32" instead of leaving all but the forward most rivet on each angle at the #30 hole that they had already been drilled. It was misleading to me in the instructions but very clear on the drawing.
