John (Jack) Clark's Web Site
Date:  11-16-2008
Number of Hours:  1.50
Brief Description:  Cut and drilled hardwood for the rear rotisserie
Cut and drilled hardwood for the rear rotisserie. I'm using #8 x 3" screws and nuts to hold the wood sandwich together. After the rear rotisserie stand is welded, I plan to countersink the nuts into the front part of the most aft piece of wood and then machine screw the pipe floor flange to this piece of wood. A 1" pipe will screw into the flange and this pipe will be inserted into a 1.25" pipe so that it can rotate. Castering wheels will be welded onto the stand. With wheels on the rear and front, the fuselage rotisserie will be mobile
Fwd wood tie down cutout
First wood aft of bulkhead
Aft wood bolted in place
