John (Jack) Clark's Web Site
RV-A8
Started the rudder pedal assembly
Started the rudder pedal assembly by marking the F-810B Attachment Angles for pilot holes. Drilled the pilot holes to #40. Fit the Angles in position.
Fabricated the F-8115 Thrust Washers (2). They were made from HMW plastic and turned out well.
Pilot holes marked and drilled
Start of Thrust Washer
Finished Thrust Washers
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
