Installed F-841 Pushrod then cut the tabs off of the Horizontal Stabilizer that hold the elevators in the trail position. The F-841 Pushrod is just barely hitting the bottom of the opening in the F-811E Bulkhead through which the pushrod passes. I'll probably have to trim the opening to clear the pushrod movement. I'll call Van's first.
