Brief Description: Attached and drilled the Floor Panels' stiffeners
Attached and drilled the Floor Panels' stiffeners after cutting and deburring the stiffeners.
Attached Forward nutplates for the Flap Bearings and the aft holes of the Aft Control Mount. The fwd nutplate rivets of the Flap Bearing Block was hard to squeeze. I tried to use a grinded vise grip jaws to squeeze the rivet but got nowhere. I progressively squeezed the rivet with a rivet squeezer and got a less then perfect but adequate result. The nutplate doesn't move.
