Brief Description: Started bolting Rt gear weldment to center section
Started bolting Rt gear weldment to center section. The lower bolts are a bear to insert from the front due to the slope of the front floor and close tolerances. I will consider installing them from the rear for final assembly is there is no interference issues. I got smart and used cheap hardware store hardware for all of the other holes. Easier to install and avaoid using the expensive bolts at this stage.
