Fit Left gear weldment, opening the floor hole as necessary to install weldment. Had a hard time installing the weldment until I realized that a nutplate installed on the top flange of the center section was blocking the path of the upper part of the weldment. Discovered that the kit was short 10 of the 14 AN3-6A bolts needed to install the weldment.
