John (Jack) Clark's Web Site
Date:  3-2-2008
Number of Hours:  2.50
Manual Reference:  8-40
Brief Description:  Made F-896 & F-897 Reinforcement Angles
Made F-896 & F-897 Reinforcement Angles. I'm glad that I test fit both piece to the F-893 L&R Forward Floor Ribs. The instructions call for centering the F-896 Angle on the F-893, drilling the holes using the match holes in the F-893, and riveting the angle to the floor rib. This would have caused a mis-match with the F-897 Angle making the F-897 angle look too short on the forward flange when it is butted against the F-896. The drawing shows the F-896 flat on the floor and flat against the F-893. Positioned like this, the F-897 angle beautifully matches the F-896 once the corner radius of the F-897 is just right. This is how it will be drilled.
1/32" removed on one edge
1/4" Corner radius on F-897
