John (Jack) Clark's Web Site
RV-A8
Clecoed Aft Bulkheads to Aft Side Skins
Clecoed Aft Lower Longerons and Aft Bottom Skin, with the F-811 F-812 bulkheads riveted to it, to the Aft Side Skins.
Clecoed the F-857C Angles and the F-808, 809, 810 Bulkheads to the Aft Side Skins
Riveted the aft ends of the F-818 Baggage Ribs to the F-808 Bulkhead.
Aft bulkheads clecoed
Baggage Rib riveted to F-808
Baggage Rib rivets to F-808
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
