John (Jack) Clark's Web Site
RV-A8
Clecoed the Aft Side Skins in place
Surface converted then primed the contact areas of the F-807A bulkhead. Clecoed in place and then riveted the F-817 L&R Outbd Seat Ribs to the F-807A.
Riveted the F-818 L&R Rear Baggage Ribs to the F-807 Bulkhead and F-814 L&R Inbd Seat Ribs after riveting the F-818B Seat Rib Angles on the F-818 L&R.
Added nutplates to the F-888 L&R Mid Longerons, the inspection plate opening on the F-824 L&R Aft Side Skins and the F-818B Seat Rib Angles.
Back riveted the F-888 Mid-Longeron onto the F-824 L&R Aft Side Skins. Sprayed the contact surface with Zinc Oxide Primer.
Lt Baggage Floor Rib riveted
Mid-Longerons riveted in place
Lt Aft Side Skins attached
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
