John (Jack) Clark's Web Site
RV-A8
Start fuselage final assembly
Spray can primed forward floor contact areas common with the lower longeron and center spar.
Bolted the lower ongerons to the forward floor with AN-3 5A bolts. The bolts were torqued to 25 in-lbs and marked with Torque seal.
Riveted lower longerons in place.
Clecoed the forward/center/mid sections together.
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
