John (Jack) Clark's Web Site
RV-A8
Primed aft bulkheads and riveted them together
Primed aft bulkheads (F-807/808/809/810B/811/812) and riveted them together.
Riveted the primed F-812A/F-812C/Tie Down Bracket together.
Drilled and deburred F-818B L&R Aft Baggage Angle and F-818 L&R and F-818D Bellcrank rib.
Assembled, drilled, deburred, converted, and primed the F-857B L&R Seat Belt Bracket, F-857D and F857E L&R Outbd and Inbd Seat Belt Brackets.
Riveted rear tie down bracket
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
