John (Jack) Clark's Web Site
RV-A8
Assembled F-811 Bulkhead, drilled and converted
The replacement F-811 bar arrived today. Made the other F-811B Stabilizer Attachment Bar. Tapered both bars to reduce weight.
Assembled F-811 Bulkhead, drilled, disassembled, deburred the parts, and converted the surfaces.
Assembled the F-810B bulkhead assembly and drilled the F-810C angle attachment. Surface converted the bulkhead.
Waiting for more parts to be primed before doing them as a batch to mininmize cleanup.
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
