John (Jack) Clark's Web Site
RV-A8
Put bend in the new F-823 for the right side
Put bend in the new F-823 for the right side. Attached the F-823 without much difficulty. The bend was good and fit well with some massaging.
Clecoed in the right side arm rests.
Need to cut a hole in the right F-823 for rear ventilation.
Rt side Mid fuselage skin
Rt rear bend fit well
Armrests clecoed in place
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
