Brief Description: Bent Lt F-823, cut a 2 5/8" hole in F-815A-R
Bent Lt F-823 after having called Van's and talked to Joe. This time I gently curved the skin enough "to get it started". Joe said that I will massage the skin into place when I attach it.
I cut a 2 5/8" hole in F-815A-R for routing of the rear air vent hose. Will have to wait for the arrival of the repalcement F-823 skin to cut a similar hole in the skin.
Attached the center section to the seat rib sub-assembly. Matched drilled the #30 holes common to the F-814E L&R seat supports and the F-814A L&R inboard ribs .
