Brief Description: Riveted F-814A L&R to F-814G, HPPX, + F-805D
Riveted F-814A L&R to F-814G, HPPX, F-805D and F-814C together. The callout for attaching the F814C to the F-814A was for a 4704-4 rivet but that was too short. Therefore I used a 4.5 rivet with good results.
Attached the aileron trim brackets to the F-814A L&R
Riveted the F-814A & B to the Rear Spar Bulkhead Attachment Assembly.
Riveted the F-813 L&R aft outbd seat ribs to the Rear Spar Bulkhead Attachment Assembly.
Clecoed the Bottom Center Skins onto the rib assembly
