Brief Description: Primed the Seat Rib Subassembly
Primed the Seat Rib Subassembly (SRS). I was waiting to get back from Oshkosh prior to buying a HVLP Detail sprayer. I got the sprayer from Harbor Freight and it worked quite well. I also sprayed the Cooling Air Ramp assembly.
Tomorrow, I'll spray the Forward Floor Subassembly parts. These parts will be the hardest to get to for corrosion proofing after final assembly of the aircraft. Therefore, I want to pay particular attention to this area now. I'm not yet convinced that the other parts of the aircraft need priming after I surface converted and sealed the parts. But this area is an exception.
