Brief Description: Bent the F-898-L Auxillary Longeron
Bent the F-898-L Auxillary Longeron The first attempt at the F-898-L Auxillary longeron was too aggressive in the bend, bending the longeron to about 10/32" at the center instead of 5/32". You do have to check and re-check the surfaces due to bending in one direction does result in warping of the other surface. The accompanying photos are close but with some more work, they measured 5/32" and layed flat on the table.
