John (Jack) Clark's Web Site
Date:  5-22-2007
Number of Hours:  3.00
Brief Description:  Flange material removal from F-804A
Flange material removal from F-804A using the Dremel tool and a sanding drum. The material was slowly removed with frequent fitting of the landing gear weldments until the weldments sat flat on the F-804A web and there was about a 1/32" clearance with the weld.
The pictures show how the far the weldment is held off of the web prior to the removal of some of the flange material.
Gap between web & weldment
Weldment flat against web
Material removed for weldment
