Brief Description: Reemed the aileron bellcrank brass bushings
Reemed the aileron bellcrank brass bushings. Applied grease to the bushings. Installed the bellcranks in the wings. Needed to remove the upper bellcrank bracket prior to being able to install the bellcrank. The hinge brackets were re-attached and torqued to 25 in/lbs and the lower bellcrank nuts were torqued to 50-60 in/lbs to still give the bellcranks the least amount of resistnce to movement yet be within torque specs (50-70 in/lbs).
