Brief Description: Started fabrication of FL 406 A+B+C
Started fabrication of FL 406 A+B+C. Made a measurement error on the FL406B piece. Marked stock cut using the wrong side of the ruler. One side being 32nds and the other being 64ths. Would have had enough material to make both 406B pieces with the right cut. Instead, I had to order some more 1/4" material.
