Brief Description: Checked the right tank for leaks
Checked the right tank for leaks. There were two areas of leakage. One, in the first bay, would be easy to fix. The other, in the middle bays, would require cutting an access plate into the baffle.
Riveted the Leading Edge to the spars with Tom's help. Even though it was a one man task, his help really sped up the completion.
