John (Jack) Clark's Web Site
Date:  9-15-2014
Number of Hours:  1.00
Brief Description:  Filed the Nose Wheel Turn Limiter
Filed the Nose Wheel Turn Limiter that was rubbing on the front half f the nose wheel fairing. I reversed the direction of insertion of the attachment bolt for the nose wheel swivel. I also added tgwo washers to the head of the bolt because the bolt length beyond the not was so long that it was contacting the front half of the nose fairing and damaged it. I repaired the damaged fairing. In the process of changing th direction of insertion of the swivel bolt, I had to loosen the tension bolt at the bottom of the swivel. Therefore, I had to tighten the bottom nut and check the breakout force of the swivel. It was between 22-25 lbs.
