Brief Description: Calibrated the SDS ECU to the Magnet Position
Calibrated the SDS ECU to the Magnet Position of the timing cam. This the important, do once, setting so that the ECU knows where the magnet position is relative to BTBC. The instructions give a normal range. The Magnet position on the ECU is set within the range at 74 degrees.
