Brief Description: Sprayed UV Smooth Prime on the Cowling Halves
Sprayed UV Smooth Prime on the Cowling Halves. This will need todry for at least 7 days before it can be covered with a protective layer of urethane primer. The high built UV Smooth Prime will have to be sanded smooth prior to the top primer. Then the cowling will be protected until it is finally painted or covered with vinyl.
