Brief Description: Started the installation of the right capacitance
Started the installation of the right capacitance fuel sender by prosealing the BNC connector ti the inboard ribs and completely covering the wire connection with proseal out to about 3/4" from its insertion into the connector. Applied proseal to the screw and nut of the outboard sender plates and applied a fillet of proseal to the wire insertion point to the terminal connector for the plates.
Re-checked the shop heads on applied proseal to any head the appeared to evenly remotely possible of leaking.
