Brief Description: Installed anti-hangup bracket in the left tank
Installed anti-hangup bracket in the left tank.
Sealed the shop heads of the left tank by brushing on proseal using acid brushes that had their brissles cut short to stiffen them. This worked well. Tried adding a small amount of MEK to the proseal to loosen it up a bit. This worked well with the brushing.
