John (Jack) Clark's Web Site
RV-A8
Countersunk Holes on Left Spar Flanges
Fabricated a templete using 0.032" scrap that was drilled and dimpled for a #8 screw. Did the same for a #6 screw and a n AN-3 rivet.
Countersunk the #8 Tank Attachment Hole to accept the dimples tank skins.
Countersunk the #6 Wing Inspection Panel holes.
Countersunk the remaining Skin/Rib Holes on Left Spar Flanges to accept the dimpled wing skins riveted with AN-3 rivets. Lots of holes.
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
