Brief Description: Rewired the Prop Controller Connector
Rewired the Prop Controller Connector according to the online maunal's configuration for the dSub Connector using Controllers. Tested the controller. Voila!! The blades changed pitch. It was beautiful! It was a good day!
Secured Wiring Around Prop Controller. Prior to working on the prop controller, there were wire bundles secured to the top and the bottom of the controller. Now, all of the wires pass over the controller and are secured in position.
