Brief Description: Re-installed the Timing Chain and the Cover
Re-installed the Timing Chain and the Cover. The timing chain was installed with the chain index links matching the corresponding indexed teeth of the AVCS and Exhaust Cams on both sides and the aligned index links of both chains at the cam gear.
The Timing chain cover was installed using black RTV along all edges and around mating surfaces for the center bolts. The hex head bolts were torqued in sequence in compliance with the Engine Service Manual.
