Brief Description: Moved the Coolant Tank Medially and Forward
Moved the Coolant Tank Medially and Forward using Steel standoffs to move it forward away from the firewall. I used fender washers in both sides of the firewall to stiffen the firewall. A nut on teh forward side of the firewall sandwiched the washers against the firewall. The standoffs were slid over the full length threaded stainless steel 1/4" screw and secured to the tank using locking nuts.
