Brief Description: Fine Sanded the Right Forward Corner
Fine Sanded the Right Forward Corner first using a long PermaGrit sanding block then progressing to finer and finer foam sanding blocks. The finish with the foam sanding blocks is pretty smooth. Imperfections are esier to feel after this fine sanding.
