Brief Description: Sanded the Contour of the Cowling Forward Bottom
Sanded the Contour of the Cowling Forward Bottom. Re-applied micro mixture to the thinned areas. Applied a long strip along the right bottom, fore to aft in the bend of the bottom. This area needs to be raised. Applied a layer higher up along the side of the left cowl half so I can sand the side inward to remove a slight bulge in the left side bottom.
