Brief Description: Sanded UV Smooth Prime then Re-Sprayed
Sanded UV Smooth Prime then Re-Sprayed 3 more coats. After sanding with 120 grit sanding foam, the fiberglass felt quite smooth. The re-coats were applied to fill some defects and to help with the transition areas.
