Brief Description: Wet Sanded the Skirts to 400 Grit
Wet Sanded the Skirts to 400 Grit. Will need to continue the sanding. I sanded the entire skirt to a near finish. The left side more so then the right side. But since this is a first time event, I didn't want to be too aggressive and sand through the epoxy coats. Initially, I dry sanded the left side with a 100 grit foam sanding block. This did OK but once I switched to the wet sanding with the 400 grit paper wraped around the foam block, the sanding seemed to go much faster and with good results.
