Brief Description: Pulled the Tape and Plastic Off Windscreen
Pulled the Tape and Plastic Off Windscreen. The edge of the windscreen was nice and crisp until I pulled the last bit off of the right lower corner of the windscreen. There, the edge got a bit jagged. the tape may have been just not perfectly placed on the corner, leaving the bottom yellow tape slightly underlying the final sanding of the corner. As it was removed, the yellow pulled up from underneath and caused the rough edge. The area was re-taped to double layers and an epoxy/micro/flox mixture was applied to the area. The tape was placed slightly off from the edge line to form a new edge line that incorporated the jagged edge.
Worked on the windscreen to canopy fairing transition, sanding and shaping.
