Brief Description: Installed the Rear Seat Back and Seat Belts
Installed the Rear Seat Back and Seat Belts for both the front and the back seats. Had to grind the seat belt grommets in the mounting holes in order to be able to insert the mounts into the seat belt anchors. The Pilot seat lap belts need an extension to move the adjustor away from the cushion. As it is now, the are tight against the coushions and will be sat against. This will be uncomfortable and difficult to adjust the seats. I had heard about such extensions before but I didn't unserstand what the problem was to require them. Now I do. I'll have to call Hooker.
