Brief Description: Fit Windscreen Relative to Planned Access Panels
Fit Windscreen Relative to Planned Access Panels. This was the first time of matching the windscreeen to the canopy. I discovered that I had a problem. To get the windscreen and the canopy edges to match, I had to raise the forward tip of the windscreen about 1/4-1/2". At some point, too much was removed from the front tip. After some contemplation, I don't foresee a realy problem moving forward. I plan to glue the windscreen in place with SikaFlex. The gap can be filled with the SikaFlex and this gap seal will also act as a vibration and stress reducer on the windscreen since the SikaFlex is somewhat flexible. The fiberglass fairing of the windscreen will be the real structure for securing the windscreen in place and this will more then adequately cover the gapped area.
