Brief Description: Sanded the Aft Transitional Areas of the Skirt
Sanded the Aft Transitional Areas of the Skirt.
Applied a layer of glass to the transitional area of the left side of the skirt. This was to strengthen the area as well as to help with the transition from aft to side skirt contour. I think this will work quite well. I'll probably do the same to the right side tomorrow if all works out well.
Applied micro to the right transitional area of the skirt.
