Brief Description: Glassed the Inside Aft Joint of the Canopy Skirts
Glassed the Inside Aft Joint of the Canopy Skirts. I used three layers of 9 0z. glass of inceasing length applied after sanding tapered edges around the opening.
Applied some microballon mix to the inside fracture line. This will be sanded then a layer of glass will be applied to reinforce the fracture line.
