Brief Description: Re-glassed the Canopy Skirts Aft Joint
Re-glassed the Canopy Skirts Aft Joint due to poor cure of the epoxy resin. I suspected a problem last night because the mixture looked slightly different. I have to watch the amount of hardener dispensed carefully because when I pump to dispense, the first half pump only delivers the hardener to the tip of the spout. I believe that last night I mixed the epoxy with less than needed hardener.
