Brief Description: Heat Formed the Upper Lip of Both Canopy Skirts
Heat Formed the Upper Lip of Both Canopy Skirts. To so this, I applied pressure to the upper lip of the Canopy Skirt with the end of a 1" x 6" board while I applied heaat to the lip using a paint stripper with a wide nozzle fitting. I held the sections heated in place until the fiberglass cooled to touch. Then I applied some tape to hold the position in case there was any material position memory. The results where noticable and quite good.
