John (Jack) Clark's Web Site
Date:  9-17-2012
Number of Hours:  4.00
Brief Description:  Sanded Filler and Adjusted the Skirt Top Lip
Sanded Filler on both skirts and Adjusted the Skirt Top Lip on the Left Skirt using a heat gun and a board. I used the board to apply pressure along the top of the skirt as I loosened the fiberglass with heat. I held the position of the top lip until the fiberglass cooled to a comfortable level of touch. I applied some duct tape to the lip to keep the lip in place while cooler further and to discourage the lip from returning to its original position in case it had some retained memory. The resuts where quite good. I will do the same to the right side next.
Aft 3rd Rt side gap
Aft 3rd Rt side gap
Rt side aft Skirt with small gap
Hard to see gap but it is there
