Brief Description: Tested the Intercom and the Radios First Time
Tested the Intercom and the Radios First Time with a headset plugged into the Pilot Position and then the Copilot position. Able to talk with a side tone on the intercom from both positions. Therefore the intercom works. Getting steady static from both the G430W and SL40 radios. Able top receive from a handheld on the G430W but unable to transmit. Unable to transmit from the Copilot position and I am unable to disable the Copilot Stick Grip with the Disconnect Switch. These problems will be now need to be fixed.
