Brief Description: Sprayed Primer of the Empennage Fairings
Sprayed a Light Coat of Primer of the Empennage Fairings. There were many pin holes. I sanded the pieces again particularly where the holes were concentrated. I will try using the UV Smooth Prime to fill the holds and to again try for the smoothest surface I can get.
