Brief Description: Finished the Throttle Cable Installation 1
Finished the Throttle Cable Installation. I moved the cable bracket about 3" away from the throttle lever. This corrected the limited lever throw. I had to fabricate the a mount for the cable at the throttle body in order to be able to secure the cables sheath. After much frustration, I was able to insert the throttle cable and rear throttle push/pull rod clevos pins into the throttle lever from the rear of the lever. I then was able to insert cotter pins after more frustrations. The good news is that the job is done and it works well.
